Suzuki Grand Vitara XL7 2.0TD RHW ECU(Beyin) Arıza Kodları
GRAND VITARA XL-7 2.0 HDI ECU RHW Engine (EOBD Spec)
https://www.obd-codes.com/
ENGINE:
DTC P0100 (P0102 / P0103 / P3007 / P3008): Mass Air Flow Circuit (Low Input / High Input / Plausibility at Low Flow / Plausibility at High Flow)
DTC P0110 (P0112 / P0113): Intake Air Temperature Sensor Circuit (Low / High)
DTC P0115 (P0115 / P0117 / P0118): Engine Coolant Temp. (ECT) Sensor Circuit (Malfunction / Low / High)
DTC P0220 (P0222 / P0223 / P0224) / P2299: Pedal Position Sensor Circuit Malfunction
DTC P0180 (P0182 / P0183): Fuel Temperature Sensor Circuit (Low / High)
DTC P0190 (P0192 / P0193 / P0194): Fuel Rail Pressure Sensor Circuit (Low / High / Intermittent)
DTC P0089 (P0089 / P0087, P1113 / P0088, P1116 / P0094): Fuel Pressure Regulator Performance (Malfunction / Fuel Rail Pressure Too Low / Too High / Fuel System Leak Detected - Small Leak)
DTC P0201 (P0201 / P0261 / P0262 / P1372): Injector Circuit - Cylinder 1 (Malfunction / Low / High / Short)
DTC P0202 (P0202 / P0264 / P0265 / P1373): Injector Circuit - Cylinder 2 (Malfunction / Low / High / Short)
DTC P0203 (P0203 / P0267 / P0268 / P1374): Injector Circuit - Cylinder 3 (Malfunction / Low / High / Short)
DTC P0204 (P0204 / P0267 / P0268 / P1374): Injector Circuit - Cylinder 4 (Malfunction / Low / High / Short)
DTC P1169 / P1170: Condenser Voltage Too Low / High
DTC P0215: Engine Shutoff Solenoid
DTC P0230: Fuel Pump Primary Circuit
DTC P0243 (P0243 / P0246) / P0245 (P0245): Turbo Charger Waste Gate Solenoid (Malfunction / High) / Turbo Charger Waste Gate Solenoid Low
DTC P0234 (P0234) / P0299 (P0299): Turbo Charger Over Boost Condition / Under Boost
DTC P0380 (P1351 / P1352 / P1349 / P1350) / P1404: Glow Plug Circuit Malfunction
DTC P0381: Glow Plug Indicator Circuit
DTC P0401 (P0401): Exhaust Gas Recirculation Flow Insufficient Detected
DTC P0400 (P0400 / P0402 / P2143 / P2145) / P2144 (P2144): Exhaust Gas Recirculation Flow Malfunction
DTC P0105 (P0107 / P0108): Barometric Pressure Sensor Circuit (Low Input / High Input)
DTC P0561 (P0642 / P0643): Sensor Reference Voltage Circuit (Low / High)
DTC P0603 (P0603) / P0604 (P0604): Internal Control Module Keep Alive Memory (KAM) Error / Random Access Memory (RAM) Error
DTC P1107 (P2009 / P2010): Intake Manifold Runner Control Circuit (Low / High)
DTC P0480: Fan 1 Control Circuit
DTC P0481: Fan 2 Control Circuit
DTC P3004 (P3005 / P3006): 3rd Piston Deactivator Circuit (Short / Open)
DTC P0090 (P0090 / P0091 / P0092): Fuel Pressure Regulator Control Circuit (Malfunction / Low / High)
DTC P0606 (P0606) / P1171: ECM Processor / ECU Function (ECU Internal Fault)
DTC P0120 (P0487 / P2142) / P2141 (P2141): Exhaust Gas Recirculation Throttle Position Control Circuit (Malfunction / High) / Low
DTC P1511: Ignition Switch Circuit Malfunction
DTC P0485: Fan Power / Ground Circuit
DTC P0650 (P0650 / P1642): Malfunction Indicator Lamp (MIL) Control Circuit Malfunction (Malfunction / Open)
DTC P0608 (P0658 / P0659): Actuator Supply Voltage Circuit 1 (Low / High)
DTC P0609 (P2670 / P2671): Actuator Supply Voltage Circuit 2 (Low / High)
DTC P0225 (P0224 / P0227 / P0228 / P2137): Pedal Position Sensor “No.2” Circuit (Intermittent / Low / High / Voltage Correlation)
DTC P0335 (P0335): Crankshaft Position Sensor Circuit
DTC P0340 (P0340 / P0343 / P0344 / P0016): Camshaft Position Sensor Circuit (Performance / High / Intermittent / Crankshaft Position - Camshaft Position Correlation)
DTC P0500 (P0500 / P0501): Vehicle Speed Sensor (VSS) (Malfunction / Performance)
DTC P0235 (P0069 / P0235, P1281 / P0237 / P0238): Turbo Charger Boost Sensor Circuit (Manifold Absolute Pressure - Barometric Pressure Correlation / Malfunction / Low / High)
DTC P0560 (P0562 / P0563): System Voltage (Low / High)
DTC P1613: ECM Not Registered
DTC P1517: Immobilizer System Malfunction
RHW Engine (Other than EOBD Spec)
ENGINE:
DTC P0100 (P0100): Mass Air Flow (MAF) Sensor Circuit Malfunction
DTC P0101 (P0100): Mass Air Flow (MAF) Sensor Circuit Range / Performance Problem
DTC P0110: Intake Air Temp. (IAT) Sensor Circuit Malfunction
DTC P0115 (P0115): Engine Coolant Temp. (ECT) Sensor Circuit Malfunction
DTC P0121 (P0120) / P0604 (P0120): Throttle Position (TP) Sensor Circuit Malfunction
DTC P0180: Fuel Temperature Sensor Circuit Malfunction
DTC P0190 (P0190): Fuel Rail Pressure Sensor Circuit Malfunction
DTC P0191 (P0230) / P1112 (P0230): Fuel Rail Pressure Sensor / Pressure Regulator Malfunction
DTC P0201 (P0200) / P0202 (P0200) / P0203 (P0200): Injector Circuit Malfunction Cylinder 1 / Cylinder 2 / Cylinder 3 / Cylinder 4
DTC P0215: Double Relay Circuit Malfunction
DTC P0230: Fuel Pump Supply Circuit Malfunction
DTC P0243 (P0243): Turbo Pressure Solenoid Valve Circuit Range / Performance Problem
DTC P0245 (P0243) / P0246 (P0243): Turbo Pressure Solenoid Valve Circuit Range / Performance Problem
DTC P0380 (P0380) / P1404 (P0380): Pre / Post Heat Relay Circuit Malfunction
DTC P0381: Glow Indicator Lamp Circuit Malfunction
DTC P0401 (P0903) / P0402 (P0903): EGR Solenoid Valve Flow Insufficient Detected / Excessive Detected
DTC P0403 (P0403): EGR Solenoid Valve Circuit Malfunction
DTC P0561 (P0560): Stabilization of Sensor Supply
DTC P1107: Swirl Control Solenoid Valve Circuit Malfunction
DTC P1108: Radiator Fan High Speed Circuit Malfunction
DTC P1109: Radiator Fan Low Speed Circuit Malfunction
DTC P1110: A/C Signal Circuit Malfunction
DTC P1135: 3rd Piston Deactivator (Injection Pump Solenoid Valve) Circuit Malfunction
DTC P1138 (P0230): Fuel Pressure Regulator Circuit Malfunction
DTC P1402 (P0510): Throttle Solenoid Valve Circuit Malfunction
DTC P1519: Radiator Fan Circuit Malfunction
DTC P1606: MIL Circuit Malfunction
DTC P1608: ECT Warning Lamp Circuit Malfunction
DTC P1614 (P0560): Sensor Supply Function
DTC P0221 (P0220): Throttle Position Range / Performance Problem 2
DTC P0335 (P0335): Crankshaft Position Sensor Circuit Malfunction
DTC P0340 (P0335 / P0340): Camshaft Position Sensor Circuit Malfunction
DTC P0500 (P0500): Vehicle Speed Sensor (VSS) Circuit Malfunction
DTC P0235 (P0235): Intake Air Pressure Sensor Circuit Malfunction
DTC P0560 (P0560): Power Supply Circuit Malfunction
DTC P0603 / P0606 / P1171: ECM Function
DtC P1169 (P0170) / P1170 (P0170): Condenser Valve Function 1 / Function 2
DTC P1101 (P0105): Barometric Pressure Sensor Circuit Malfunction
BRAKES
DTC C1013 (No. 13): System Specifications Different from ABS Control Module Specifications
DTC C1015 (No. 15): G Sensor Circuit and 4WD Circuit
DTC C1021 / C1022 / C1025 / C1026 / C1031 / C1032 / C1035 / C1036 (No. 21 / 22 / 25 / 26 / 31 / 32 / 35 / 36): Wheel Speed Sensor Circuit
DTC C1041, C1045, C1055 / C1042, C1046, C1056 (No. 41, 45 / 56): Inlet Solenoid / Outlet Solenoid Circuit
DTC C1057 (No. 57): Power Source Circuit
DTC C1061 (No. 61): ABS Pump Motor Circuit
DTC C1063 (No. 63): ABS Fail-Safe Relay Circuit
DTC C1071 (No. 71): ABS Control Module
Automatic Transmission/Transaxle
DTC P0705 (No.34): Transmission Range Sensor Circuit Malfunction
DTC P0717 (No.14): Input / Turbine Speed Sensor Circuit No Signal
DTC P0722 (No.31): Output Speed Sensor Circuit No Signal
DTC P0741 / P0742 (No. 78 / 77): TCC Circuit Performance or Stuck OFF / Stuck ON
DTC P0751 / P0752 (No. 62 / 61): Shift Solenoid-A Performance or Stuck OFF / Stuck ON
DTC P0973 / P0976 / P0985 (No.22 / 24 / 49): Shift Solenoid “A” Control Circuit Low / “B” Control Circuit Low / “E” Control Circuit Low
DTC P1740 (No.75): Cruise Control Signal Malfunction
DTC P1875 (No.15): 4WD LOW Switch Circuit Malfunction (Open)
DTC P0707 (No.34): Transmission Range Sensor Circuit Low
DTC P0711 (No.81): Transmission Fluid Temperature Sensor Range / Performance
DTC P0712 (No.38): Transmission Fluid Temperature Sensor “A” Circuit Low
DTC P0713 (No.36): Transmission Fluid Temperature Sensor “A” Circuit High
DTC P0756 / P0757 (No.65 / No.63): Shift Solenoid-B Performance or Stuck OFF / Stuck ON
DTC P0771 / P0772 (No.67 / No.66): Shift Solenoid-E Performance or Stuck OFF / Stuck ON
DTC P0781 (No.68): 1-2 Shift
DTC P0797 (No.79): Pressure Control Solenoid “C” Stuck ON
DTC P0962 / P0966 / P0970 (No.41 / 43 / 45): Pressure Control Solenoid “A” Control Circuit Low / “B” Control Circuit Low / “C” Control Circuit Low
DTC P0963 / P0967 / P0971 (No.42 / 44 / 46): Pressure Control Solenoid “A” Control Circuit High / “B” Control Circuit High / “C” Control Circuit High
DTC P0974 / P0977 / P0986 (No.21 / 23 / 48): Shift Solenoid “A” Control Circuit High / “B” Control Circuit High / “E” Control Circuit High
DTC P1701 (No.76): CAN Communication Problem - TCM
DTC P1702 (No.83): Internal Control Module Memory Check Sum Error
DTC P1703 (No.86): CAN Invalid Data - TCM
DTC P1874 (No.15): 4WD Low Switch Circuit Malfunction (Short)
DTC P2742 (No.59): Transmission Fluid Temperature Sensor “B” Circuit Low
DTC P2743 (No.58): Transmission Fluid Temperature Sensor “B” Circuit High
DTC P2763 (No.26): Torque Converter Clutch (TCC) Circuit High
DTC P2764 (No.25): Torque Converter Clutch (TCC) Circuit Low
Air Conditioning System
DTC B1501 (No.01): Outside Air Temperature Sensor and Its Circuit Malfunction
DTC B1502 (No.02): Inside Air Temperature Sensor and Its Circuit Malfunction
DTC B1503 (No.03): A/C Evaporator Temperature Sensor and Its Circuit Malfunction
DTC B1504 (No.04): Sunload Sensor and Its Circuit Malfunction
DTC B1510 (No.10): Engine Coolant Temperature (ECT) Sensor and Its Circuit Malfunction
DTC B1511 (No.11): Temperature Control Actuator (Position Sensor) and Its Circuit Malfunction
DTC B1512 (No.12): Air Flow Control Actuator (Position Sensor) and Its Circuit Malfunction
DTC B1513 (No.13): Temperature Control Actuator and Its Circuit Malfunction
DTC B1514 (No.14): Air Flow Control Actuator and Its Circuit Malfunction
DTC B1520 (No.20): Temperature Selector and Its Circuit Malfunction
DTC B1521 (No.21): Blower Speed Selector and Its Circuit Malfunction
DTC B1522 (No.22): Air Flow Selector and Its Circuit Malfunction
Air Bag System
DTC B1015: Passenger Air Bag Initiator Circuit Resistance High
DTC B1016: Passenger Air Bag Initiator Circuit Resistance Low
DTC B1018: Passenger Air Bag Initiator Circuit Short to Ground
DTC B1019: Passenger Air Bag Initiator Circuit Short to Power Circuit
DTC B1021: Driver Air Bag Initiator Circuit Resistance High
DTC B1022: Driver Air Bag Initiator Circuit Resistance Low
DTC B1024: Driver Air Bag Initiator Circuit Short to Ground
DTC B1025: Driver Air Bag Initiator Circuit Short to Power Circuit
DTC B1031: Power Source Voltage High
DTC B1032: Power Source Voltage Low
DTC B1035 / B1037: RH / LH Forward Sensor Circuit Open or Short to Ground
DTC B1036 / B1038: RH / LH Forward Sensor Circuit Short between Two Wires or Short to Power Circuit
DTC B1041 / B1045: Driver / Passenger Pretensioner Initiator Circuit Resistance High
DTC B1042 / B1046: Driver / Passenger Pretensioner Initiator Circuit Resistance Low
DTC B1043 / B1047: Driver / Passenger Pretensioner Initiator Circuit Short to Ground
DTC B1044 / B1048: Driver / Passenger Pretensioner Initiator Circuit Short to Power Circuit
DTC B1051: Frontal Crash Detected (System Activation Command Outputted)
DTC B1061: “AIR BAG” Warning Lamp Circuit Failure
DTC B1071: Internal SDM fault
DTC B1013: System Specifications Different from SDM Specifications
Body Electrical Control System
DTC B1121: DRL Circuit Malfunction
DTC B1131: Illumination Control Input Circuit Open (H27 Engine Model Only)
DTC B1141 / B1142: Outside Air Temperature (Ambient Temp.) Sensor Circuit Open / Short to Ground
DTC B1156: CAN Communication Error (H27 Engine Model Only)
DTC B1170 / B1171 / B1172: Factory Register Error / Memory Check Sum Error / Memory Write Error
Immobilizer Control System
DTC 11 / 31: Transponder Code Not Matched / Not Registered
DTC 12: Fault in Immobilizer Control Module
DTC 13 / 14: No Transponder Code Transmitted from Ignition Key / Coil Antenna Circuit Malfunction
DTC 41: ECM Not Registered
DTC 42: Serial Data Circuit Malfunction (between Immobilizer Control Module and ECM)
DTC 43: ECU Code Not Matched
ENGINE:
ENGINE:
BRAKES
Air Bag System
Re: GRAND VITARA XL-7 2.0 HDI (EOB RHW ECU(Beyin) Arıza Kod
Ek olarak görüntülenen ODB kodları bu web sitesinden de detaylı olarak incelenebilir.
Re: Suzuki Grand Vitar 2.0 HDI (EOB RHW ECU(Beyin) Arıza Kod
emekli suzuki çi olarak dan bi el atayım dedim..
https://www.google.com/search?q=garmin+ ... SSonMkHC3M:
garmin 5 inç navigasyonum vardı ..
+ olarak 100 küsür dolar verip bu zımbırtıdan almışdım 125-130 gibi..? +nakliye + gümrük vs bunu 5 li gösterge olarak yıllarca kullandım
elektirik şarzından tut.. turbo basınçı, hararet motor,, içeri giren havanın sıcaklığına kadar vs yol bilğisayarı oluyordu..
+ günde ne yaktı haftada ne yaktı..?performans raporu verip şöfer liğini imtahan edip puan filan da veriyordu..arızaları söyleyip sıliyordu..
dolar o zaman gazoz parası idi deyim.. 2. el denk gelirse kaçırmayın derim.. :Pimalat dan kalkmış an ça 2 el uyguna bulunur dedim teknoloji eski şimde neleri cıktı vs..
https://www.ebay.com/p/Garmin-Engine-Mo ... 1001541816
bulunmaz hınt kumaşı olunça kıymete binmiş yuh dedim 170 dolar çekmişler..
- Kayıt: 04 Kas 2014 16:15
Re: Suzuki Grand Vitara XL7 2.0TD RHW ECU(Beyin) Arıza Kodları
bizim türk sitelerinde satılan özellikle bluetoot bağlantılı cihazlar bu araçta okuma yapar mı ? yada tavsiye ettiğiniz yurt içi bir cihaz varmı . alıp kullanmak istiyorum
Bende ELM 327 var Torkqe programı indirdim cep telefonumdan ecuya bağlanıp arıza kodlarını rahat görüyorum, hata düzeltmesinden sonra arızaları silebiliyor.( ücretsiz versiyonu bendeki)
teşşekürler bilgi için . şuan 48 tl civarı n11 gibi sitelerdee bu ürün var . bende alıp kullanacağım . herkese dikkatli sürüşler
merhabalar bugün aracımın arıza lambası yandı . experde söndürmüşlerdi kodlar p0380 p1517 p0400 kabaca kızdırma bujisi dediler diğerlerini de listeden baktım anlayamadım . acaba bu kodların hangi parçalar olduğunu bilen varmı . teşekkürler
Arızalarınız ve açıklamaları aşağıdaki gibi. Önce beyinden tüm arıza kayıtlarını silin bazen arıza kayıtları anlık geçicide olabilir..sonra gelen arıza kodalarına göre yapılacak işlemleri belirlemek lazım..bunun için tecrübeli bir usta lazım.
(Kızdırma Bujisi Devresi Arızası) Bu hattın röleden başlayıp bujilere kadar bölümü ve kızdırma bujileri kontrolü gerekiyor. Basit bir kablo kırığı kopuğuda olabilir arızalı ısıtma bujiside olabilir, buları kontrol eden rölede olabilir.
İmmobilizer sisteminde bir arıza olabileceğini belirtir.İncelenmesi lazım.
P0400 Arızasının Sebepleri (Egzoz Gazı Yeniden Çevrimi (EGR) Akış Arızası):
*EGR kanalları ve boruları kurumdan tıkanmış.
*EGR valfi kurum kaplanmış ve aşırı kirlenmiş.
*EGR valfi bozuk (Bkz: EGR Valfi Arızası).
*EGR valfi bir elektrikli motorsa kablo-soket bağlantısında elektriksel arıza var.
*EGR valfi bir diyaframlı vakum/basınç tüpüyle çalışan tipteyse; diyaframlı tüp arızalı, diyaframı yırtılmış, sıkışmış yamulmuş olabilir.
*EGR valfi bir diyaframlı vakum/basınç tüpüyle çalışan tipteyse; diyaframlı tüpe vakum/basınç dozajlayan selenoid valf arızalı olabilir. Bu selenoid valfin kablo-soketlerinde elektriksel arıza olabilir. Bu selenoid valfin ince hortumları çatlak-yırtık-gevşek-çıkmış olup sızdırıyor veya tıkanmış olabilir.
bilgi için teşekkürler anahtarımda bir sorun var bazen açmıyor bazen ters komut çalışıyor . şuan maslak uğur anahtarda çip tamiri yapılıyor . bahsettiğiniz röleyi söktük şase ayağında pas çıktı temizledik taktık . egr ye geçmedim . arıza lambası yanmıyor . röle ektedir
Tamir başlamış çözülmeyecek arızalar değiller, inşallah kısa sürede hepsini çözersiniz, gelişmeler ve arızaları nasıl çözdüğünüzü detaylı yazın ki sizden sonra bu sayfaları okuyanlara yol göstermiş olursunuz.
İmmobilizer hatası gibi duruyor, önce arabanın orjinal veya diğer anahtarı ile startı deneyin olmadı anahtarı yapan bir yer ile görüşün derim hepsi olumsuz olursa, araç beyinlerine program atan yerler var ecu docktor, remaps gibi bu firmaları arayın, nasıl sonuçlanacak bende merak ediyorum, kolay gelsin.
İstanbul-Bostancı grand oto ahmet usta ile muhakkak görüşüp fikir alın, Suzuki elektriği konusunda çok iyidir, yönlendirme yapacaktır.
Salih aracın durumunu hangi arıza kodunu gördün ne yaptın gibi buradan devam et, bu başlık altında toplansın bilgiler.
- Kayıt: 14 Oca 2014 21:59
Sistemde dönem dönem p1352 p0069 P0380 kodlarım vardı dün sabah marş basmadı sorunun bunlardan kaynaklandığını düşünmüyorum.Usta tekniğiyle çalışıyor araç tornavidayı biryerlere sokuyorlar herhalde. Vurdurarak sanayiye getirdim çalışır halde denedim 2-3 sefer marş basıyor. Stop ettikten sonra 1-2-3. sefer marş aldı 4.de almadı marş.O şekil bıraktık elektrikçide kontaktan marş dinamosuna kadar olan yerde problem olduğu düşünülüyor.Akü olduğu düşünüldü ama şarj edildiğindede marş almadı.Gelişmeler buradan devam edecek
Trabzon Merkez
2004 Grand Vitara 1.6 3k
Ölümü unutmadan hayata devam
Instagram:@gezgorgezz
tornavidayla + yı direk marş motoruna deydiriyor . yaptığı bu . ama çeviripte almama durumu varsa bir çok nedeni olabilir . bekliyoruz
Benimde bu sabah yolda arıza lambam yandı (P2141): Throttle Position Control Circuit (Malfunction / High) hatası verdi, hadelen dedim,
Şirkete gelince ODB2 portumda ELM327 var Torque programını açıp cep telefonumla beyinden arızayı sildim, kontağı kapatıp anahtarı çıkardım, sürücü kapısını açıp kapadım ve yeniden çelıştırdım. Arıza lambası söndü araç normal.
Ustamın şahsıma açıklaması aşağıdaki gibidir.
Motor iç tesisatında birkaç düzenleme yapıldı ve uzaktan kumandanda problem vardı.Arkadaşımın aracılığıyla 150lira verdim.Helali hoş olsun.
Trabzon Merkez
Ne yaptıklarını detaylı öğrenip yazarsan senden sonra bu arızayı görecek olan Suzukicilere yol göstermiş olursun..hengi kablo hangi soket ne gibi bir işlem birşeyimi iptal ettiler nedir detay çok önemli.
Abi hata doğru tespit edilemediği için çözümüde yok aslında kendi kendine düzeldi diyelim aslında.
Trabzon Merkez
